I have the computer running WinXP Pro and the laptop running WinXP Home. I installed the remote desktop utility on XP Home. I am sharing drives and printers using a router between the two computers and everything works fine. I can access the PC through the laptop using Remote Desktop. The problem is I CAN NOT access the laptop using Remote Desktop on the PC. I get the following error:
Any ideas? I searched all over google groups and microsoft and couldn't fine a solution
Remote Desktop Disconnected
The client could not connect to the remote computer.
Remote connections might not be enabled or the computer might be too busy to accept new connections.
It is also possible that network problems are preventing your connection.
Please try connecting again later. If the problem continues to occur, contact your administrator.
OK Help
