Thanks, which remote would you recommend for turning a TV on and off through the wall?![]()
TV remote controls use IR (infared) which travels in lines and doesn't go through walls. You would need to look for something based on RF.![]()
Some universal remotes use both IR and RF. They'll come with an extender so it'll be pretty obvious that they do. If you're happy with your current remote you can always just buy an IR extender.
