Bedrock1977
- Dec 20, 2010
Hello - I am new to this forum and need help accessing my Cisco Rack remotely. I have the 2509-RJ Access Server installed and am able to access it via telnet within my home network. However, when I try to access it remotely, it fails each time I try. I set up a domain through dyndns.org specifically for the rack, the same thing I use for RDP to access my home computer remotely. RDP uses port 3389, which I opened up in the firewall and directed that port to my computer's internet IP. I tried opening up port 23 for telnet acccess to the IP address of the access server, 192.168.1.150. I believe the problem is with the dyndns.org domain I set up. The one I use for RDP has my public IP address attached to it. I tried doing the same thing for port 23 and routing that to the access server and it fails. Does anyone have some pointers on how to fix this?
Thanks,
Bedrock1977
Thanks,
Bedrock1977
