aNtHrAx323
- Mar 10, 2000
I was doing a little cleaning out of my closet (just moved back home from IL for a little while, so I figured I'd get all my old shit cleaned out for my next move in a couple months) and came across a forgotten gem from years ago - a Panaflo "Purple Orb". I had ordered it with the intent of using it for cooling my Socket A processors (it worked with a little ghetto-fabulous zip-tie fabrication), but as I migrated away from AMD it went to rest. Well, out of curiosity, I did a fit check in one of my P4 boards and found that the proportions (W/H wise) are identical to the P4 heatsink mounting frame, but about 3mm smaller in each aforementioned dimension. Does anyone have any ideas as to how I could craft a mounting mechanism to attach this beauty? Or any that might currently be available that could work? I'm interested in seeing how well it works, because face it... Using a relatively old, cooler-than-hell looking RISC-intended heatsink on a P4 would just be [H]ard. Let me know your thoughts.
