adrenaline0210
- Aug 4, 2006
I am currently running a asrock 939 dual sata2 mb, 4x512mb twinmoss ddr400, x1900xtx stock cooled, raptor 74 gig, seagate baricuda 120 gig, (all sata), cpu is a 939 x2 4200+ oc'd to 2.69ghz stable, cooling is a thermaltake se watercooled. All of this in a thermaltake tsunami case. I am going to be going with a d5 danger den pump, not sure of what rad- thinking the dual 120mm that ill mount on the top of my case, tdx cpu block and maze 4 gpu block all 1/2"id with tygon.
?'s i have is what rad should i go with?.... I really like the fitting setup on the thermaltake how u slide the coupling over the tube and tighten it looks way neater than zipties over barbs, how and where do u find 1/2" id fittings for these blocks that would be similar? As for resivoir im leaning twords the invotech fass-o-matic barrel tank, looks really cool mounted on top because the bubbles come up to the window... please any suggestions or help would be greatly appriciated.
