Reliable mobo makers
RancidWAnnaRIot
EspantaPajaros
What are good mobo companies.. all i've ever built with is Abit, and gigabyte.. what are other good/reliable mobo companies?
Asus
Abit
Gigabyte
MSI
Older Epox stuff.
That's what I've used and had good luck with. I haven't hit up others yet.
Intel
Asus
Tyan
MSI
SuperMicro
Alot of those are higher end server based boards. Some of the others like Asus, Intel and MSI are more universal.
I think anyone can say their company is reliable because virtually 99% of them are. It just depends on the random faulty product, or incompatability with yur computer, where its not the board-makers' faults... I have had 2 mobos for my computer in the past. The first was a really old Socket 370 one with my Pentium1 166 MHrz... I think it was from ASUS. Now, my second is a much better Socket 370 board, which runs my p3 750 MHrz. It is a CUSL2-C from ASUS. My brother's is an ASUS Appolo or something. My dad's is, I'm guessing, an ASUS. :)
I have had problems with all the companies except intel. Their boards just seems rock solid time and again.
There are manufacturers that are more likely to have reliable mobos, but they all have put out boards that have issues and aren't corrected for several revisions. A lot of stuff going on on a motherboard, and they also have to be cheap as hell. I have personally had issues with abit, asus, msi, epox, etc. I guess the for sure thing is that if you buy a mobo on its first revision your asking for trouble. I like to buy close to top of the line when I upgrade so I run into trouble sometimes. Most problems are fixed with bios upgrades, but many are not. Also several of the problems I have had are chipset problems not necessarily bad mobo design problems.
While I haven't had any particular problems with mobos, I tend to buy them when the techs have matured.
I really like Intel motherboards for stability, because overclocking potential is not the most important thing in many cases.
Abits I like too, as well as Asus and Gigabyte. Haven't had much experience with the other famous ones like MSI, Tyan, Epox, Supermicro, etc.
Although I think many will agree that you should stay away from PC chips.
Yeah avoid PC-Chips or Matsonic or any junk like that. ECS is another one that bites. But they've got a couple fairly reliable models. They blow for OC'ing though. Tyan has always made good server market boards as does SuperMicro. They tend to be extremely feature rich and on the expensive side. MSI is just a good solid board company that makes boards that just about anyone can afford.
I generally prefer Asus for a few features plus I still think Asus has better quality. But I wouldn't hesitate to use MSI in a system.
Typically I have always liked the layout of Abit boards. Always liked the features, but I have always had problems with their boards. So as a result I don't buy from them.
