Porter_
- Sep 10, 2007
MS has relased a reliability update for Vista:
KB941649 address the following issues:
It extends the battery life for mobile devices.
It improves the stability of portable computers and of desktop computers that use an uninterruptable power supply (UPS).
It improves the reliability of Windows Vista when you open the menu of a startup application.
It improves the stability of Internet Explorer when you open a Web page.
It improves the stability of wireless network services.
It shortens the startup time of Windows Vista by using a better timing structure.
It shortens the recovery time after Windows Vista experiences a period of inactivity.
It shortens the recovery time when you try to exit the Photos screen saver.
It improves the stability of Windows PowerShell.
A compatibility issue that affects some third-party antivirus software applications.
A reliability issue that occurs when a Windows Vista-based computer uses certain network driver configurations.
http://www.dailytech.com/article.aspx?newsid=9160
EDIT: HEARING WORD THAT THIS MAY CAUSE ISSUES WITH 64BIT OS.
