Releasing plastic cable clamps
Trick that I use:
Bust out a couple pairs of needle-nosed pliers, grab the fat end at either side of the grippy portion, and use a clockwise or anti-clockwise twisting motion to slide the grippy teeth apart (e.g. both wrists go clockwise or both wrists go anti-clockwise). That help?
*edit* That allen key idea doesn't sound bad either
Another way, if you are using a taller type barb, is to just slip them apart. I.e. move the outside up, and try to push the inside down if possible. They come off pretty easily for me this way.
