How should I go about Reinstalling xppro? When I insert the cd it ask it repair xp or new install.... I tried repair and all that did was reinstall the main components and kept everything on drive C:... WHen I select new installation it ask if I want to dealte a previous partitions or do a new install. What do I do ???
Its a custom built system I had put together hrmmmm...
Thank you.
Thank you.
