So I'm reinstalling windows on my notebook. I have a single 40 gb hdd, and I want to get optimal performance out of it. I'm thinking about doing this 1 of 2 ways:
1. Two partitions. First partition for OS and paging file, approx. 5 gigs. Second partition for apps and documents, etc.
2. Three partitions. First for OS, second for paging file and third for apps, documents, etc. If I went this route I would want to make the paging file partition hidden somehow. I remember reading how to do this once, but have since forgotten.
My questions are these:
1. Which option is better? I realize the second option will result in slightly lower performance than the first, but I also think it would be easier to keep the paging file partition clean of unwanted junk with the second. If there is a way to keep anything unwanted from writing to the OS partition, including myself, That would also be good.
2. If I go with the second option, I would like to know how big to make each of the 2 first partitions. I don't know how big to make the OS partition, and would like suggestions on how large to make the paging file partition. For reference, I have 1 gig of ram and the most intensive program I run is Photoshop CS.
Thanks for any help you can give.
