My laptop had a bit of a mishap and well ended up having to repair the install of the OS to get power management back, but now its only partially there.
under power options i can ONLY select home/desk profile and cant create anything new, and sleep mode only enters s1 mode, (cpu stopped, vid off) not s3 like it used to (cpu OFF, HD off, vid off, ram slow resume)
Is there a way i can edit this (regedit/system cfg?) or reinstall it (drivers) or someway to make sure when i repair it again it gets the correct install (i heard pressing f5 while "setup is checking your hardware" will bring up ACPI compability menu)
Anything i can do to get this to work would be great, i tried just reinstalling the whole OS on another drive to see if that works but that wont find ANY of my hardware so thats not much of an option
This is a Dell i8600 1.6 centrino w 1/gb ram, and latest bios
