reinstall napp-it
Hi,
because of some strange problems i want to reinstall my omni OS with napp-it.
At the moment i have rpool and tank.
Is it possible to import the comstar's logical unit(s)? And if yes how?
Or would the backup/restore feature suffice?
I tried it with a test system and do not seem to be able to import the LU's.
Thanks in advance
Martijn
You have different options
If you created iSCSI targets using the simple way in napp-it where you can set a filesystem to
share iscsi=on in menu ZFS filesystems, you can re-enable it by simply re-activate the iscsi share.
If you have created complex iSCSI settings in menu Comstar, you can save/restore these settings
in menu Comstar > Save/Restore (require that you manually save/restore the config file).
The napp-it backup functionality saves this among others to a datapool. You must restore
napp-it settings in /var/web-gui/_log manually ex via WinSCP.
Last option is that you import a logical unit in menu Comstar > Logical Units > Import LU.
You can import zvol or filebased LUs but must recreate groups and views manually.
If you had replicated a zvol, you can import the Zvol as a LU but must (re) assign a GUID.
This can be done in the import menu.
Hi _Gea,
thanks for your reply.
It takes a little while (lun shows up @ esx as a dead-link at first) but it works.
The LU's only appear after restoring the BKP file?
Thanks again!
