TkBF said:Just FYI. I'm using Kingston ValueRam DDR2-667 KVR667D2N5/512 x 4, I OC these rig upto DDR2-910 pushed by 2.425V voltage power, it's rock stable at this speed, and I know these ram can be OC even higher because I found my bottleneck is CPU temp with stock HSF full load at FSB=458 / Temp=68C. At this point, Prime95 will fail on CPU test but RAM test is OK.
Currently running GA-965P-DQ6 / Bios=F6e / E6300 w stock fan @ 3185 MHz / FSB:455 / Multiplier=7 / FSBRAM=1:1
I'm not sure how Kingston DDR2-533 will perform, but I am surpprised by their DDR2-667 ValueRam.
Regards
Regards
smilepak said:Wow..did you have a heatspreader on that?
