Registry help
Klowinns
Hi,
I recently ran a software called Pit Stop, after running this software some Internet Sites won't work. How can I repair this problem?
Many thanks in advance.
did u uninstall it? go to your internet setteings in IE and make sure the correct proxy server is set. some programs change these settings sometimes for them to work.
Klowinns said:
Hi,
What do you mean by "won't function?" Does it give you any sort of error message?
