Refurb Xbox 360 - $179.99
Going to have to show my roommate this. Caught him looking at the 360 on the scam site. His credit card was out and was ready to purchase. If anything, you can do the x-clamp fix
I thought all Pro models were Falcons?
The Premium with no HDMI was the Xenon, then there were Premiums that were Zephyrs with and without HDMI. All Pros have HDMI. I would honestly call them to make sure they meant to say Pro and not Premium.
I called the Micro center closest to me and they said no HDMI, so these are actually premium, not sure is mixed premium and pro, but the santa clara store said no HDMI.
not all pro are falcons. The new ones maybe. Ones with HDMI could be an Opus or Zephyrs (pre-falcon). All pre-Opus (i believe) do not have HDMI
Not bad for including the hard drive. If it didn't, would be a terrible deal.
I would avoid refurbs like the plague... especially if you don't know whether they've RROD'd or not in the past. Due to the nature of the RROD, it is impossible to restore it to the original state short of prying the GPU off of the motherboard and re-balling it. This pretty much means you're guaranteed a failure sometime down the line.
You might get lucky and get something that simply had a DVD drive error, but I wouldn't count on it.
If your really paranoid about buying a refurb then you could always do a Squaretrade warranty on it. A $180 value 1 year warranty is $21.99 and there is a 50% off code SUMMER50 that you can use to bring that down to $11.
