Refurb Sapphire 9800pro... this is weird.
Tengis
I just recieved my refurb 9800pro from Newegg.
First of all, the packaging was horrible. The card was wrapped up in a GIANT antistatic bag, with layer upon layer of scotch taped wrapped around the card.
The card uses a fdd power connector, my other 9800pro uses an hdd power connector (molex). What gives? Is this something I should be worried about? Is there any way to test this video card to make sure it doenst have problems? Ive installed about 8 different 9800pros and none have ever had the fdd connector.
Anyways, I just got back from Texas (17 hour drive). I will come back and update when Im more awake.
Not quite, it looks like that... except... the heatsink is Silver, and the area around the FDD connector looks alot different.
erm...
I know the 9700 Pros have the FDD connector, but its reconized as a 9800pro. It is very akward. I think it performs in the realm of the 9700 pro too. I have 2 identical computers (almost) and the one with the new 9800 got about 3700 in 3dmark03, while my older 9800 gets around 5700. What gives?
The first rig is in my sig, 2nd is:
Biostar M7ncg 400
2500+ @ 2090mhz
(512 x 2) 1g pc3200 3-4-4-8 (I think, Im not at home to check right now)
180g Hitachi Deskstar
refurb 9800pro 128mb
Around the FDD connector it looks like there could be 2 more areas to solder 2 more FDD connectors onto the pcb directly under the existing FDD connector. Ill try to take a pic later and get it online.
ah that's a 9700 pcb used to make 9800se's but then I guess they changed it to a 9800pro instead. I got mine and it has that connection, check the ram online mine came with 3.3ns samsung ram.... I got a damned good deal for 121 but you might have gotten screwed on the ram.
~Adam
Is it possible that someone couldve somehow returned a flashed 9800se? =(
Also, it doesnt look like a 9700pcb, it is a bit different.
a little difference is not too hard to do in mfging.
what is your ns on your ram?
mfging? I will check the ns when I get home.
I am about to send this to newegg customer support, any suggestions on changing anything or taking anything out? Its kinda long, so bear with me.
Thanks again for any help you guys are giving me.
I just recently bought a refurb Sapphire 9800pro from you guys. I finally beat through my busy schedule and got around to playing with it today. But it seems as though I didnt even get a 9800pro. Please read... =).
First of all, the card was HORRIBLY packaged. Did you guys do this? It was placed into an antistatic bag and then the top of the bag seemed to have been crumpled and taped up. There was a ton of scotch tape holding the mass of antistatic bag together. It also seemed to have been forced into the box with some of the cables and accessories, and could have possibly damaged the card.
Well, I thought, no biggie. As long as it works.
Sure enough, ya it works... but upon closer inspection, my video card has an FDD power connector (not the hdd/molex that a 9800pro should have). Immediatly I assumed something had happened and I got a 9700pro, but the drivers noticed it as a 9800pro so again... no biggie right?
I run 3dmark03 a couple times to make sure it works fine and I get horrible numbers (3000-3500 each time). I take out the card, put my BBATI card into the computer, and run the tests again after reinstalling the drivers. I get 5500-6000 3dmarks each time I run it.
After running my older 9800pro through the same tests, I picked up this new refurb and begin looking at it. It seems as though the stickers on the back that signify what video card it actually is had been tampered with.
My conclusion:
Somehow, someone returned a 9800se or 9700pro that had the bios flashed to a 9800pro bios. It would explain the stickers on the back (because they wouldve moved the stickers to the flashed card), the horrible 3dmark score, and the fdd connector instead of the hdd/molex.
I know its a refurb... and I know when you buy refurb products your taking a chance, but in no way did I sign up to buy a 9700/9800se that was flashed. Like I said, the card works, it only has horrible performance and all of the signs of something gone wrong. Ive bought many refurb products from you guys before, and everything has actually turned out 100% to my satisfaction.
Please, get back to me asap.
Thanks! Zack Garten
I discovered the problem, they sent me a 128bit 9800pro instead of the 256 I ordered... err...
yes... let this be a lesson that saving $10 and not getting an OEM or even Retail is not worth it :p
Im going to complain and hopefully get something for free... =).
They just screwed me, it wouldve been a good deal otherwise.
My conclusion:
Thanks! Zack Garten
You actually sent this email to Newegg? Newegg is NOT the HardForum, if you expect courteous service you need to be courteous and professional. Forum speak is not going to get you what you want. You should have approached the issue professionally, which means writing "Please read =)" at the top. That isn't going to make you any friends. Also, don't write the email like you are having a conversation by asking the reader questions. This makes you look like a 10 year old.
I agree that it sucks that you got the shaft on the video card, but I've found Newegg's email support to be quite helpful whenever I've dealt with them. It is most likely the person reading that horrendously written email has little idea as to what you are talking about. Maybe you should try again, and try to be more mature about it next time.
No, I didnt send them that email. I figured out that the card I recieved was a 128bit before I decided to send that.
Hey there
I recently ordered a refurb Sapphire Radeon 9800pro
128mb from you guys, but unfortunatly you have sent me
the wrong card. I orderd a 256bit 128mb card, and I
recieved a 128bit 128mb card.
I ordered this: N82E16814102268R
You guys sent me this: N82E16814102369R
I love newegg... this is the first time you guys have
ever gotten anything wrong. Please let me know how we
can go about resolving this issue. Thanks.
Please get back to me asap, this card was meant to go
into a system I was building for a customer and now Im
somewhat behind schedule.
Thanks again
Zack Garten
Thats what I sent
Oh, ok. I was going to say, your other email was decidedly lacking.
