refurb cards fault in doom 3?
Flavorite
just recieved a refurbed HIS 9800pro from newegg and i'm having problems playing doom 3. Bumped the resolution up to 1280 x 1024 and have the graphics on normal. Gameplay is mostly smooth, will run into a few bumps every once in a while.
EIther doom 3 or my system crashs after about 20-30 mins of gameplay, mobo temps are around 42c. Is there a program out there that will test my video card out... I did just also turned my system down to 2.2ghz. I did use the driver from ati's website, instead of the one from HIS.
Errr, the video card just stopped responding on me while typing this(not the first time its has done it)... The VPU recovering thing saved me(again)... I think this card will be getting send back. :mad:
Try running Prime95 for at least a few hours to test your system stability. If it errors out, then it may not be your video card.
If Prime95 runs fine, then try running benchmarks like 3DMark03 and letting it loop for a while. If you are running an ATI video card, make sure to turn off fast writes when running Doom 3. With it on, all of my ATI cards had artifacts.
After that, you could also try slightly upping voltages in your bios. Maybe try memory or agp voltage.
BTW, is anything still overclocked? If so, have you tried everything at default?
i have a refurb 9800pro from newegg and mine runs fine for hours. i had some coworkers who had stability problems with ati cards and doom 3 and i recommended they installed the omega ati drivers. everybody i told says it works great after that.
http://www.omegadrivers.net
my thought on refurb 9800's are that people bought them thinking they were r360 cores, and when they see they are r350's they send them back. mines an r350 ddr2 card, and 2 other people in know also bought refurb's and both are r350's also.
