Refresh Rates
Nut_Case
Noob here, have a question on refresh rates. i currently have it set to 75 htz. is their any benefit to setting it higher? the highest my will go is 85htz.
____________________
Pentium 4 Processor,2.6cGHz,800MHz Front Side Bus
Asus P4P800VM Motherboard 865g chipset (Micro ATX)
128MB Nvidia GeForce FX5200 Video Chipset(Asus Card)
1024MB (2X512) Geil Ultra DDR400 memory 2-3-3-6
Hitachi Deskstar 80GB Serial ATA Hard Drive 7200 RPM,8MB Buffer, 8.5 Seek Time.
Lite-On CDROM/CDR/CDRW 52X32X52
Intergrated Sound
Chieftec Infinity Case
PowerUp 400 Watt Power Supply
Samsung SyncMaster 17" Flat Screen
Windows XP Home Edition
3 Case Fans(2 intake 1 exhaust)
Depends on the monitor, really... if you have an lcd/FPD then it's best that you read your manual and check for the optimal refresh rate... and with a CRT, just make sure you're above 75.....then play around till you get the setting that looks best to you
Note that on many monitors higher refresh rates tend to be blurrier than lower ones.
Low refresh rate => wavy screen
max refresh rate => less sharp images
So, just find the sweet spot for your eyes (usually between 75-100hz).
