Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
power down everything, unplug your monitor from your system and plug it back in.
If that doesn't work, remove your graphics card from your motherboard and put it back in.
Restart your computer in safe mode (press F8 repeatedly as the machine boots before you see the Windows Logo loading screen and then select "safe mode"). I'm pretty sure that if you change resolution and refresh rate there, it will stick when you reboot into standard mode. There is also a "VGA mode" that is similar. But I'd try Safe Mode first.
Nope, b/c I switched both moniters around and the same thing happened (New computer=notworking) Could it be the graphics card, but all the fans are turned on including the GPU fan.
Reset the BIOS via CMOS jumper. That'd be the last thing I'd try before starting to suspect that your video card has died.
Pull power plug from back of the computer.
Find the CMOS reset jumper on your motherboard and place it in the reset position.
wait a minute or two.
Put the jumper back where it was.
Power up.
If you still have no video, I'd start to get worried.
