I just had an odd thought.
The framerate that a computer can produce in a given game is a measure of the number of frames it can render per second, and the refresh rate of a monitor is the measure of the number of times per second a monitor changes its picture, right?
Then if most LCD monitors max out at 60Hz refresh rates, and others at 75Hz, is it a waste if your computer can push more than 75FPS in a game? Is there going to be no actual difference whatsoever?
Sorry if I'm missing something blatantly obvious. I'm not very knowledgeable about displays and the like.
