- Sep 27, 2005
Back when we were all using IDE HDDs wasn't it true that if you had two HDDs of different speeds on one cable, then both would run at the slowest speed? Say if you had a 7200rpm HDD and a 5400rpm HDD on the same IDE cable then both HDDs would run at 5400? I've been out of touch with hardware for a while now and need some refreshing. I just did a new build (specs in sig) and I want to keep my old HDD which is a regular Raptor, not a Velociraptor. I know their RPMs are the same but their data transfer rates are different. Putting my regular Raptor in the same rig as my Velociraptor won't alter any speeds of the Velociraptor will it?
