I can't honestly see a reason to keep them separate, especially when you can easily ghost the drive if you really don't want to reinstall. Anyway, the only trick is to install the OS as normal. You won't know which programs work or not until you go to try them. But honestly, in the time it takes to do that, recopy and create shortcuts, test the apps, reinstall ones that aren't working....are you really saving any time? Add in the fact that many apps probably have updated versions. If it was my system, I'd keep it all together, but that's just me. I think you'll find that you'll spend as much or more time doing it this way, than just reinatlling them.
well this sucks since it seems like it saves a lot of time, if it did work. But I figured if Windows crashed then to reinstall they'd work arg.. Oh well. How do I save COD 4 files so I won't lose everything rank/ guns anyone know?
