Guys,
Recently my system has become slightly* unstable. I want to reformt as it is spring cleaning time. My current setup includes to Western Digital HDs. My 80 gig is hooked up via IDE and contains my OS (XP Home) and apps. My 200gig is hooked up via Serial ATA and contains my media (movies, music, install files etc.). Is it possible for me just to reformat the 80 gig? I would feel safer if I just removed the 200gig; however, when I hook it back up will XP give me a problem finding my old data? Is this an okay way to go about things? Thanks for your help in advance.
Drew
PS my 80 gig has also been quite noisy and sandra soft said i was only moving 11000kb/sec. I plan on taking everything apart and redoing the wiring. Do you think this plus the reformat will fix these slow speeds? I also have the seriallllal adaptor that came with my ABit board should I just run them both on the same serial channel?
Drew
