Reformating help...
MaMMa said:
on older BIOSs there's only about 4 pages, you should get to know it, really know it rather then asking us. I don't remember or know how your BIOS is laid out but I'd guess its in the first page or so.
If you really want us to tell u where to go exactly, take a picture of every page on the bios with a cam :rolleyes:
Im under CMOS Setup Utility...
It has
Standard CMOS Features
Advanced BIOS Features
Advanced Chipset Features
Integrated Peripherals
Power Management Setup
PNP/PCI Configurations
PC Health Status
Then on the right side it has:
Load Fail Safe Defualts
Load Optimized Defualts
Set Supervisor Password
Set User Password
Save and Exit Setup
Exit Without Saving
[Set User Password] to tank the old password
[Load Optimized Defaults] to fix your hdd problem... if it's related to the bios.
starhawk said:
most likely Advanced Bios Features.
Under that there is:
Virus Warning
CPU Internal Cache
External Cache
Quick Power On Self Test
First Boot Device
Second Boot Device
Third Boot Device
Boot Other Device
Swap Floppy Drive
Boot Up Floppy Seek
Boot up Numlock Status
Gate A20 Option
Typematic Rate Setting
Security Option
OS Select For DRAM
HDD SMART Capability
Report no FDD for Win 95
Video Bios Shadow
I did that, the hdd is still not there though, but I know its not bad so its kind of wierd, maybe it needs drivers?
starhawk said:
[First Boot Device] it should have an "autodetect" setting.
THanks for the replys bro, the first boot device has Floppy under it and then the 2nd Boot Device has HDD under it and it has HDD-0 but it doesnt have anything that says auto detect.
:rolleyes: oh god.
that means you'll have to do it the same exact way that i did it on my old 386 (it didn't work cuz the drive was borked by the emp that the psu had thrown out a day earlier)
look at the hdd settings. note the acronyms by the settings. look on the hdd itself. find the numbers for each acronym... they may have a range, in which case you're gonna be doing a bit of guessing. then just fill the numbers in.
starhawk said:
:rolleyes: oh god.
I dont know what you mean, under it I can just choose HDD-1, HDD-2, HDD-3....
[HDD-0] is what you want. people count 1-2-3... computers count 0-1-2... :rolleyes:
O i was under the impression this board was OLD OLD school. Its not that old and I dont know why ur HD didnt pick up.
Starhawk looks like he knows whats up.
In the mean time though, why dont you hook this HD as a slave onto the pc that your using now to make sure it works. While your at it, might as well format it FAT32 as well. This may help
hehehe... got 3 old comps in my house... so i BETTER know what i'm doing.
386 workstation (trying to revive but so far unsuccessful... it's where i'm pulling the bios stuff from)
p1 90mhz pavilion (my mom's backup, and until xmas 2004, our main household comp... i kid you not)
p1 150mhz (trying to sell in my fs/t thread for $50... haven't had any offers... ever.)
</thread hijack>
Im on my laptop right now...ummm when its starts up, it doesnt have anything for Primary Master and Pri Saleve Disk under IDE Drives....??
Also I guess its still not detecting, cause its still not working or its giving the same windows 98 error.
Primary Master = jumper set to "Master" on HDD, plugged into IDE cable labelled "Primary" on IDE ISA/PCI card (if it's that old) or on mobo (if it's newer than i think it is)
Primary Slave = jumper set to "Slave" on HDD, plugged into IDE cable labelled "Primary"
Secondary Master = jumper set to "Master" on HDD, plugged into IDE cable labelled "Secondary"
Secondary Slave = jumper set to "Slave" on HDD, plugged into IDE cable labelled "Secondary"
The hdd was working fine earlier, so I still think its good....
Umm I looked at the harddrive and I only see a cable connected to the power, and a cable connected from the motherboard to the hd...
I dont know what I did but I got the hdd and floppy working from messing around with some cords, blowing the dust off them etc!!
Thanks alot fellas, hopefully it goes through with the setup, ill let you know.
That's all it took? Well jesus, there goes all my time....wait...nevermind...im just typing during death breaks in counter strike. Not that i die often.
Naw, it was more then taking out and checking wires and shit, im sure setting bios to regular defualts and all helped... trust me im sure it just wasnt the wires.
But thanks fellas!!!!
no problem
only one thing that i got to know here... wtf does your friend want with a computer that's 6yrs old and runs an os that nobody supports?
Win98 support was extended and is until 2006...
They probably use it for the same reason you had! They may not have any other machines.
odd... i'd heard over a year ago that microsoft had dropped win98 support like a 16lb bowling ball from the 2nd floor into a kiddie pool
He just uses it as like a computer to get on aim and browse sites in his room, his dad bought a pretty nice computer for the whole family, but he uses there old one to mess around on.
But thanks again fellas.
Win98 & ME it were set to lose support, but because of huge demand for support, it was continued. Check out the support page for Windows 98 if you're interested :)
As for you CBlakeNS, did you set all devices to Automatic detection in the bios, and did you check the connections of all the cables?
Remember "red to one" (the red line of the ribbon cable) as the right way to put a data cable on a cdrom/hard drive . Make sure the red is closest to pin one in other words.
Already got it fixed awhile ago man, thanks for the reply though!!
I guess you skipped around reading in the thread :)
tommo said:
Whooooops, there I go again :p
Good to see it's all in order :)
Yeah I got it working fine,
He just needs to install the drivers and all and then it will be set!
Thanks for the help anyways!
