1. If you created a tool
a. User A uses the tool to improve life, what do you think? Most will be elated to be part of it.
ii. User B uses the tool to kill each other,..some say it is the human who control it..
2. Entity A, B, C, If you created tools
a. Your users use the tool to help each other, enhance life, Most will be elated to be part of it.
b. Your users use the tool to beat up each other, double-edge impacts....at this juncture a lot of arguments will come...
3. Entity A, B, C, if you marketing based on concept 2-b.
a. your users operate based on learning 2-b
b. After that, since you are part of it, consideration "man shaped by his experience", look at forum postings
b-1. U1 --> please act X to hurt B
b-2. U2 --> No it wont, anyhow please act Y to hurt A
b-3. U3 --> Maybe U1 and U2 should accelerate the process (but now U3 will immense itself into part of the cycle)
All will be pulled into the Vortex of special type of karma, together with Entity A-B-C.
next : .....
Note: I have absolutely no objection in case moderators removed this post immediately if it does not fit the requirement of this forum.
next : .....
