Reference for Logitech Setpoint?
SofaKingA
Does anyone have a legit link to a Setpoint manual or support site?
The Logitech doesn't explain the program well at all IMO. I even joined their "Support Community" and couldn't find anything. Unless I missed it, but I searched the site pretty thoroughly and did a few searches online.
I created a test profile for my new G9x with a unique yellow LED and saved it to the mouse. I then clicked the profile button on the bottom and the LED color didn't change so I know the mouse isn't switching profiles. Do I have to assign the profile to a specific program before I see the changes I've made?
Thanks.
The manual should be in the help section of Setpoint. I haven't used a G9 in a while, but I know its there.
Did you apply your changes or load the profiles to your onboard memory?
I don't know if this will help or not but I found a small descriptive paper under my manual that read this...
"To Change Profiles in On-Board Memory:"
"Press and hold Profile button on underside"
"Continue pressing Profile button on underside."
"LED will blink, indicating you are in Profile mode. While pressing Profile button, toggle through profiles with + and - buttons."
"Release Profile button, LED color will change to indicate you're in a new profile. Non-blinking LEDs revert back to indicating dpi settings."
