Hi [H],
I have some good primochill advanced LRT tubing of 3/8 ID 5/8 OD.
However all my compressions are 3/8 ID 1/2 OD (more specifically 10mm/13mm)
What is the best way to thin down the outer walls at the end of the tubing (to 1/2) so they can fit into the compression fittings? I have access to my university's machine shop, and read somewhere that a machine lathe could work for pvc pipes in other applications.
From what I read, these tubes are tight over the barbs of the compression fitting so I dont thinking it would have alot of leaking issues.
I am doing this because i don't need that much length of tubing and shipping from USA or 10ft pack for this tubing here in Canada is expensive. Also if I do it well, the tubing will look flush to the compressions, instead of compression being chunky at the end of the tubes.
