Redid My cooling loop
  • Thread starter Deleted member 134350
  • Start date
D
Guest
I redid my cooling loop shortening the tubing and re-setting the CPU waterblock. I also changed the coolant to 95% distilled water and 5% Valvoline (Zerex) Racing Super Coolant.
I replaced both rad fans with 110cfm double ball bearing models that have reostats for speed control. My loop temperatures have dropped to 36C idle and 43C loaded. After the Artic Silver 5 thermal compound cures both my GPU and CPU temps should drop, which takes from 50-200 hours.
I edited my post to reflect 95% distilled water and 5% Valvoline Super Coolant.
