USF-Nealio
- Jan 18, 2012
My current switch layout at work is very basic and offers no redundancy. I'd like to at least setup redundant core switches, so that if any of my switches would to fail, it would result in a smaller number of systems affected.
Current Core Switch: HP Procurve 3500yl-48G (3500yl-24G as cold spare)
Internet Switch: 3com (forget model)
User distribution switches: 9 Planet 10/100 Layer 2 Managed switches, and 2 Dell Powerconnect 5448
Server switches: 5 Procurve 2810-24Gs (1 in each server rack)
In addition, we have 50+ site to site VPNs using different 192.168.x.x subnets across 2 different VPN concentrators, several routers, and a pair of MPLS's.
My first step to help improve speed and reliance was to reconnect the user switches. The old distribution switches were daisy chained, and all users 120 users were on a single 1GB port on the core switch, and if switch 2 of 11 failed, I'd have 10 switches knocked out of the network. I've since connected them directly to the core switch, and the users have noticed the improvement.
I'll try to get a diagram, but it's basically a large hub and spoke. Each and every switch is connected directly to the single core switch. All of the internet sources are connected directly to the 3com and are on separate VLANs which are then connected to the core via a trunk, which then handles the routing. Currently, I'm using less than half of the ports on the current core switch, so I should still have enough ports on the 24G to at least maintain the critical systems. Each server switch is trunked to the core, as is the internet switch, but the user network is not (but probably should be). Instead they are connected via simple untagged uplinks.
I absolutely cannot afford new equipment right now, so whatever I do will require reusing existing equipment. I'd very much like to increase the bandwidth from the server switches to the core if at all possible. Is there an easy way to configure and Active-Active setup that would improve bandwidth? Or would It be active-passive and require a 2 port LAG on the 48 port (for speed), and a 3rd port for the 24 port (for redundancy).
NOTE: With any luck, we'll be dropping our analog phone system and replacing it with VOIP sometime within the next year. So I should be getting some extra budget to replace the distribution switches with POE. Until then, I'll have to live with my crappy Planets.
