- Jan 19, 2024
Howdy.
Sadly, ExtremeHW hasn't found a new owner so the forums will likely be shutting down soon. Decided to relocate this build log I had just started over there.
I thought it would be cool to do a couple of "throwback" builds with Intel + Nvidia vs. All AMD. I'm using the term throwback loosely since the hardware isn't all from the same era but the core components are mostly from around a decade ago. I'm sure the scope will continue to creep and the Intel system will end up way faster. I've already picked up a 2nd Titan Black and PPCS still has some old 780ti/Titan blocks in stock.
Parts Lists:
CPU: AMD FX-9590
Motherboard: Asus Crosshair V Formula-Z
GPU: Radeon HD 7990
RAM: Either some black and red Adata XPG 2133 Cl10 or some EVGA 1866 CL9 that I know works
Storage: A pair of m.sata Samsung drives on a Vantec RAID card , an Intel 750 series PCIe drive, and a WD Black spinning rust drive.
Case: Maingear Vybe Nero red
PSU: EVGA 850 P2
Cooling
CPU: Intel i7 2700K
Motherboard: Gigabyte GA-Z68XP-UD5
GPU: GTX Titan Black... I also have a GTX 690 that would keep it a bit more era appropriate and dual GPU for both systems. However I can't find a waterblock for the 690.
RAM: Blue G.Skill Ares 2133CL10
Storage: A pair of Samsung 850 Pro, pair of 860 Pro, and an Intel DC P4510 U.2 on PCIe adapter
Case: Lian Li V3000 Plus... Was going to use a Blue/White Maingear Shift I've had for a long time, but Microcenter dropped the price on V3000's and I had to have one lol. Also the Shift isn't really great for custom
PSU: EVGA 1000 G2
Cooling
As for fittings and tubing... I haven't decided which system is getting what. They may both end up with a mixture of hard and soft tubing. I have a decent amount of frosted 14mm hard tube and some nice brass 16mm. I also have soft tubing in most common sizes. Mostly EPDM or clear. I'll likely use up some QD3's in the Intel system since there's so much room in that case.
Parts Lists:
Red
CPU: AMD FX-9590
GPU: Radeon HD 7990
PSU: EVGA 850 P2
Cooling
- Maingear Apex distro
- EKWB Supremacy Edge Red/plexi (1/100 so fairly rare)
- EKWB FC7990 SE I'm actually not an EK fanboy, just hard to find 7990 blocks these days
- Bitspower Leviathan XF 240
- Barrowch Chameleon fish 240 Red/Acrylic
- Scythe Gentle Typhoons
Blue
CPU: Intel i7 2700K
PSU: EVGA 1000 G2
Cooling
- EK distro that was designed for an O11D that I got cheap open box
- Thermochill PA 120.4 that's coming out of retirement
- I've got a dirty old 420mm in the front for mock up but might just get another 480 to put up top and leave the front as intake.
- Currently have a Swiftech Apogee Drive II mounted on the board because I thought I was trying to stuff a loop in the Maingear Shift... May switch to a Heatkiller IV.
- Titan Black has a Heatkiller block already on it
- Lian Li uni fans... Acquired a ton of these for cheap and have been looking for a way to use them up
- Phanteks PH-F140HP II - Again, been wanting to use these up for a while.
