ManofGod
- Oct 4, 2007
Welp, let me start by saying it was time for my to upgrade my video card, to me anyways. I have a reference R9 290x from XFX and it works pretty good at 4k. (Not great but, pretty good.) I also have a i7 6700k in a Gigabyte Z170 Gaming 7 board.
So, I decided to start with a R9 390x 8G card from XFX over at Best Buy. Unfortunately, except for some pretty good jumps in benchmarks, I did not notice any difference in games. Therefore, I just returned it and stuck with my 290. Then, on Monday, I found that I could crossfire the 290 and 390 together so I purchased a XFX R9 390 from Bestbuy and installed it. Well, I was very impressed and it seem to work quite well except that the fan noise was loud and both cards were getting very hot.
I figured 3 day later, why not install 2 x R9 390's instead so I picked more of them up and installed it. However, I found that the GPU temps were getting to 94C and the fans were running very fast still so I went ahead and returned them both. (My Define r3 case just does not have sufficient cooling performance, I guess.)
Alright, Friday is here and I thought, I will buy an R9 Fury air cooled unit from XFX well it is at a good price. Well, I then found out after the purchase that the card is almost 315mm long but my case will only fit a 290mm card and nothing more. I chatted with newegg and they voided the purchase for me since I could not cancel it online anymore.
Now, that left only the 980ti of the Fury X. Since I have no place to fit the Fury X radiator, that left just the 980Ti. Ok, first to check is the $599 Gigabyte unit which claims a certain size online but when I finally got through to Gigabyte support, they said the card is 291mm. Then, I looked some more and found that the EVGA cards are short enough, called them, got through immediately and they verified the information.
Well, I checked one more card, and MSI one. Tried calling them twice, was put on hold twice and never got through to them. (Remember, I had to verify the card length since Newegg does not take returns for refunds on video cards.) Because EVGA was quick with their support, I went with them and ordered this card.
Basically, I am now on team green for at least the next 2 years since AMD had nothing I could use. Hopefully, I will not run into any issues since I am on Windows 10. Looks like EVGA is the winner to me and I even called them back and thanked them for the help. (Got through immediately again and got the same gentleman as well.)
