blueparukia
- Mar 1, 2008
Ok, I'm in a bit of a dilhemma.
I have a friend's laptop here, a Toshiba Satellite L300-ST2501 which needs to be reformatted. The laptop does not have the default Toshiba Vista operating system on (its been improperly formatted before), but it still has the 10GB recovery partition on it.
It is currently using a copy of Vista Home Premium, but with no drivers.
I tried grabbing a WiFi and display driver from here:
http://www.csd.toshiba.com/cgi-bin/...300-ST2501&selCategory=3&selFamily=1073768663
which failed [H]ard. The Wifi driver did not work, and the display driver would not install (saying minimum system requirements were not met)
So is there any way to create a recovery disc from the spare partition (pressing F8 on boot did not give me the correct options) or correct drivers for WiFi and Display?
Thank you muchly
Thank you muchly
