recovering data from a partition from another partition
FRAGMAN BOB
I know title is kinda confusing, but here is the situation. I am working on my friends gf's laptop (dell inspiron e1505). She was getting an "ntldr is missing error", I used my XP home SP2 cd to fix the mbr through the repair console. That worked fine, I went to rebuild the bootcfg with the /rebuild command and it couldnt find a hard disk!
I knew there was a seperate partition for on that disk for mediadirect (~2gb) I installed xp on there without touching the main partition, hoping that I could read the corrupt partition inside the new install. In my computer, only the smaller, new partition is recognized., but inside admin tools/disk management; it shows the full 80gb drive being split into two partitions.
Is there anyway I can access the old partition or maybe rebuild the boot.ini and boot from it? I just need to get into the install once to remove all her pictures (of her since passed away father).
Thanks guys.
Assign the old partition a drive letter in disk management and take owner ship of your GF's files
Thanks, I just assigned it the E: letter. When I attempt to access through my computer, I am getting prompted to format the partition. I checked what format it was, and it is being recognized as RAW. Think I goofed something up
Use GetDataBack or something similar. It should be able to recover the files as long as they were not overwritten. If you do format, do a quick one, not a full format. A full format should kill all the data on the partition.
