Is there any FREE software out there that will record all audio coming out of the computer? FRAPS doesn't seem to record voice from the microphone. The thing is though, it has to be low profile as it's for recording some gaming on an AMD XP 2800+.
Replay Audio.
It has a few different options, but one is it simply tapping the sound hardware, and recording directly to file.
I used it for recording MP3's from shoutcast stations. A couple of my songs have a windows beep in the background if you listen carefully, but otherwise it worked very well. It even intelligently separated songs, and used CDDB to label the files.
zv
I use a program called Magic Soft's Sound Capture. Awesome awesome little proggy. It records anything the speakers are playing to MP3 format and you can change the quality. It's use to be a free program that was freely available on the Internet however it can't be found anymore.
I have the installation file if you or anyone else wants it.
