jamezzz122
- Jun 1, 2003
Is there any program out there that can do this for me? I don't wanna record with a mic. I want like a "TiVo" for speakers. LOL. Thanks guys!
That program doesn't record the sound from the Mic?cuemasterfl said:Here: http://audacity.sourceforge.net/
I am able to record whatever my computer is playing with this.
Puterguru said:That program doesn't record the sound from the Mic?
compslckr said:if you have more than 1 speaker output on your sound card just plug a audio patch cable from an audio out to the mic jack on your sound card. the cable is like $2 at radio shack, i can find a link if you need me to.
then just use the windows sound recorder to record the audio. then you can convert it to mp3 if you want to.
you can also use the patch cable to connect any device with a headphone jack to you computer (tv, cd player, mp3 player, radio, etc.) and record whatever is being out put by that device.
i do it all the time with my sirus satellite radio while i am playing games so i dont have to run winamp
mosin said:Audiograbber can catch any stream. I think CDex can, too.
I found it on Download.com, here is the Linkrebelleader said:I use Magicsifts Sound Capture to record sound from my sound card. It works great but I cant find the download on the web anywhere. If you want it I can e-mail it to you, it is less than 1MB.
I've been using it now for the past 10 minutes. It works AWESOME! Thank you!rebelleader said:Thanks for the link. I did a google search and searched download.com for MagicSofts and the actual filename and came up with nothing.
"what u hear" is one of the recording sources on creative's audigy cards (or at least mine, an audigy 2) as well as an analog mixThe Chosen One said:isnt there a record "what you hear" option or something? Im almost positive ive seen something along those lines before, but i cant remember exactly where it was. Does this ring a bell with anyone else? Might have been in the recording settings on my Audigy drivers.
