recomond a card for me
latief75
I need a pci express card for my new setup, nothing fancy just a decent card price range around 120
what would be better
7600gt
1650pro
x1900
i'm not sure about the exact naming of the cards, but you guys should be able to figue it out......
i'm an occasioanl gamer, but i do 3d modelling, and i just plain hate weak video cards,
i am currently running a 9800pro, of course the new one has to be stronger ......
open for ideas,, and thanks:)
If you can find a X1900XT for $120, I would say get that. Still a fast card with the new games.
I went with the XFX 7600GT (TD rebate !) until the DX10 cards get more realistic and stable. No regrets and the drivers w/ Vista Ultimate X64 are stable so far.
i can't really remeber the brand, but i think it is a 400watt psu....
how will this 1900 fair against the 7600gt?
thanks for the feedback.....
I wouldn't, it's not a bad card and all - but given DX10 is the way forward, I would get nothing less at this point. Barring that, I'd suggest an interim G7x card by eVGA, so you could step-up to the low-mid range DX10/G8x cards within 90 days. We're likely to see them in retail by then, if all the rumors are true (assuming hard launch like nvidia's been doing recently).
Anyway, from a cursory glance, the 1900gt would likely outdo the 7600gt in a lot of places, but you're stuck with 'old' tech if you go the ATI route. At least w/ the eVGA, you have the option of upgrading to the newest stuff. And yes, before anyone mentions it, we don't really know how nvidia's G8x will REALLY perform in DX10 games (esp the mid levels given they're not even out yet), as there's not enough (DX10 stuff) out yet (also the [ahem] driver issues) - but at least they're here. Alternately, if you can wait, I'd say wait until DAAMIT's DX10 offerings are released into the wild, there's bound to be a better picture of what's really going on by then - and prices of NV based cards are bound to be 'adjusted' accordingly as well.
You mentioned not wanting to upgrade the PSU, what do you currently have? Brand/model #, and preferably a UL # (ie: e###### on the label near a U & backwards R). Also the other components in your system, HDs, optical(s), CPU, anything overclocked?; and so on...
what eVGA do you have in mind?
thank for the feedback, the 7600 seems to be a logical choice, although the 1650xt seems to be very similar, any info on that one?
i appreciate the fast reposnes, thanks guys
