Recommended procedure for replacing a bad drive on a RocketRAID?
unwire
Hey guys,
I have a ROCKETRAID 4320 with 10 2TB drives in RAID-6. All has been going well until recently when one of the controller started reporting repaired sectors on one of the drives (455 and growing - shown in the SHI tab of the web admin). Its also about 7 degrees hotter than the others for some reason. The card, presumably because of the bad sectors, has disabled the write cache on that drive, causing writes to the array to slow to a crawl.
I have a spare drive handy, so I thought it would be a good idea to just replace the drive that has the repaired sector count. What is the best way to replace this drive with a new one and have the array repair itself? The controller hasnt marked the array as critical, or the drive as bad, but I'd like to replace it as a precautionary measure.
Highpoint support has been completely useless - they told me that I cant replace a drive until the array is marked as critical. It seems to me that I should be able to simply yank out the drive (simulating a drive failure), put a new one in, initialize it, and add it to the spare pool, at which point the controller will adopt it and start rebuilding, no?
Thanks for your help, fellow RocketRAID users!
