Hi Guys,
I've got Core2Duo at 3.33Ghz (i.e. an Intel E8600 Wolfdale at stock speed). At the moment I'm running it with the Intel-supplied HSF. But it's running pretty hot and gets close to 70 degrees celcius at full load.
In the past I've managed to fit an Arctic Cooling Freezer 7 Pro to my Socket 775 mobo. But I've managed to wreck the last two units that I tried to fit because the plastic legs on the Freezer 7 Pro just cannot withstand the force I need to use to fit them to the mobo. (The little plastic claws on the end of the legs get bent and turned upward, wrecking any chances you have of securing the legs to the board). The Intel stock HSF has the same kind of legs but for some reason is much more robust and does not bend like the plastic on the Freezer Pro.
So my question is: apart from the Freezer 7 Pro what Socket 775 cooler could you recommend for my CPU?
It must meet the following criteria:
- be robust and able to withstand a certain amount of force while installing
- have cooling ability at least equal to the Freezer 7 Pro - preferably better
- not require me to take the entire mobo out of the case, i.e. the HSF will secure directly to the top surface of the board
- cost no more than 50 dollars
Can you guys recommend a cooler that meets all my criteria?
Thanks alot!
Cheers, Ed
Thanks alot!
Cheers, Ed
