Recommended cpu cooler and ram
Will be trying to max out bf4, arma3, pcars, and others on an i7 4770k, GA UD4H, and 780ti (already purchased). Can someone please recommend the best ram and cpu cooler that will work well together with this combo? Thank you.
Are you wanting to go air, closed loop, or full blown watercooling?
Are you concerned with noise at all? Or only care about performance?
Whats the budget?
My b. I'll keep my posts to one section from now on. Just going for the best air cooling for now. And the case is a CM cosmos 1000. The computer is in another room with an hdmi cable through the wall so no concern for noise at all, just best performance. No real budget either as the cpu cooler and ram can't be THAT expensive considering I already spent 700 on the 780ti.
