I'm looking to add lights to my Silverstone FT02 case, as it has none aside from the motherboard lighted chipset heatsinks. Seems like a simple question, but just wondered if there are any in particular that might be recommended?
I was hoping to connect it to one of my unused 3pin fan control headers, to dim it or turn it off as needed. I don't know if they allow this or not, as they seem to be small 4 pin or special in their connector.
Edit: I was thinking something like this, but I guess you have to dim it with the included rear-access slot panel, which in on my case would block air flow past the video cards.
http://www.amazon.com/NZXT-CB-LED10...leeved/dp/B0046Y7OF0/ref=cm_cr_pr_product_top
