Recommended 140mm fans?
bpizzle1
I accidentally broke one of the fan blades off one of my case's front intake fans while cleaning the case, so I figure it's a good excuse just to go ahead and replace both of the intakes. I'm looking for something with a good median between quiet and airflow. I don't have a massive OC to cool or anything, and since I'm currently in a small apartment, sound is at a premium. What would you guys recommend?
I was personally looking at:
Cougar 140mm
and
Corsair 140mm
The Corsairs are a bit more expensive than I was hoping for too.
If you have to weigh airflow against noise, here's a good graph :
Link
Those are 120mm, but 140mm designs are mostly scaled up versions, so the values would be a linear approximation of what the graph demonstrates.
It shows that the Corsair edges out the Cougar only at high rotation speeds. Otherwise it's a marginal difference.
The B-gears B-blaster fans boast pretty good specs, and reviews are generally good. Double-ball bearing design is similar to what is used in the Gentle Typhoons.
The cougar is famous for its grinding noise when mounted horizontally. I think that the corsar 140mm is overpriced. Thats a lot of money for a case fan.
I tried the B-gears B-blaster and I found it to be loud at lower speeds.
I like my Arctic cooling F14. I think that its a decent fan for the price. Its very quiet and pretty cheap.
