I have been checking out test-benches and I have found a few I like and was seeing if I could get some feedback on those that have/used them.
Why Test-Bench over a Case? I like the openness of them. I currently have all my parts laying on my desk and would still like it to be open air but in a neater fashion.
the only problem with the benches I like are the lack of support for 3 120.3 rads Neatly.
My two favorites are
Dimastech Easy Dual V2.5
Microcool Banchetto 101
The Dimastech should support either 2 vertical on one side and 1 horizontal or vertical on the other, OR all 3 on one side Vertical which would be the neatest of the choices.
The banchetto can support 2 on the back and with some modding I should be able to add the 3rd somewhere.
External mounting for the rads is not an option, being as I want a pickit up and go option making Caselabs or Mountainmods cases out of the equation due to their size.
With all that being said would it just be easier to make my own?
Thanks in advance
Thanks in advance
