Not a color one, just plain old black & white is just fine. I know HP, Brother, and Samsung have some fairly low end models that can do networking and I'm interested, but the price difference between the non-Ethernet versions and the Ethernet-enabled versions seems a bit drastic (like $75 or higher difference) so I'm curious to know what other people think.
I have two laptops, in the same apartment, and a wireless router so I'd prefer to leave the printer with the router so that either machine can print at any time. I'd be using it with Windows but also with the MacBook I'm going to buy in the next week or so, but I shouldn't expect it to be an issue anymore for driver support across both OSes.
Just curious if people have recommendations or opinions on their own setups. Color isn't a concern, if it becomes one I can just grab some low end inkjet, but I do print a lot of technical information so B&W is all I really need.
Thanks...
Thanks...
