Recommendations for 8x10mm chipset cooler
Kid8
hello i just moved to a better watercooling setup and i love the results. but my nb is running kinda hot between 40-50 c sometimes higher. I would like to watercool it but i need a block that will fit on my asus sli premium board and will not get in the way of my vid cards. I am running 8x10 tubing and using compression fittings. any suggestions will be greatly appreciated.
I ran into the same problem figuring out what blocks I am going to use. The best solution looks to be the Innovatek block.
http://www.frozencpu.com/ex-blc-172.html
Alpha Cool has one too, but you would have to buy the fittings seperately and i don't think you can get it in America yet.
It looks like it will because the threads sit out pretty far, but I have not seen a pic of an SLI board with that block. Being that the block name has SLI in it, I am assuming it was desinged for just that. The Aqua Computer one will not fit because of the barbs being to close to the upper card.
ok now that one makes more sense. now only if frocencpu would carry it :(
This what you need and you can get it here. Can be had with 8/10mm compression fittings right here :D
top nurse your the best if it works. my only concern is that the fitting will not allow for me to tighten the fittings around the tubing because on my cuplex pro it jsut barely worked out. They would touch the tighter you got them.
That picture is the Alphacool block. The link is for the Aquacomputer block. I emailed Sharka and they said with the Aquacomputer Block and Compression Fittings you can not lock down the tubing.
bummer thats what i thought thanks llars
ok so i decided i prolly will not be using sli antmore or in the near future so i was wondering if thid block will fit w/ogetting in the way of a single vid card:
http://www.frozencpu.com/ex-blc-262.html?id=By5Rt4qu
again i have the asus premium board.
o and one more quick question. i ordered the aqua computer pump from sharka and i got the compression fittings and i love it but i think im goin to swap out the straight fitting on the intake w/an elbow fitting. do i want 1/8 or 1/4 thread. when i went back and looked at the sight they list 1/8, 1/4, and 3/8 thread for the fittings. a little confusing is all. thanks again
i just added that chipset cooler to my loop. Gonna test it out tommorow.
i ordered from sharka, and got the 3/8" barbs which are a tight fit with hose clamps but doable. Anything will be an improvement from that loud chipset fan. :p ;)
But what about compression fittings? That's what both of us want to use...
Top Nurse said:
That IS the picture of the AC block. Here is some of my own pics:
Then both companies are using the same block and someone is misinformed about its compatibility with Compression Fittings.
The fittings will screw in but then you won’t be able to screw the compression caps on, so the answer is no.
Sorry.
Sharka Sales
Sharka Corporation
16182 Gothard Street Unit L
Huntington Beach, CA 92647
www.sharkacorp.com
Ooops! My bad....wrong pic :eek: Have to quit posting after taking care of trauma patients as my brain seems fried. :eek:
Here are the correct pics:
Here ya go...
You can see the issue here with the stock 8mm compression fittings.
Here is with one of the 8mm compression nuts fitted on.
So the bottom line is that the stock AC 8mm compression fittings are not going to work. However, I think the nuts could be spun down to fit if you are an enterprising soul. A lathe would make short work of this, but you could also probably ghetto it with a drill press and a file. If you are into apartment machining like I am I suppose a drill motor and a file would suffice. Sharka has a lathe in the back of their warehouse so you might be able to talk them into spinning them down for you. :)
Some other possible options would be to use an 8mm x 10mm push-fit as IIRC Alphacool and other companies sells those. Here is a pic of the 10mm on a G 1/8 thread.
Hmmm, this is making me leary about the Alphacool block as they look similar.
will the bigger push fiitngs fit on there or are they to wide to work as well?
also i looked on sharka and could not find the larger push fittings
This might be a better solution
sharka-computers_1876_1054096
Assuming the block is not too thick to interfere with the cards.
llars said:
This might be a better solution.
First of all I would suggest that you not hot link images off of someone elses website as it is considered bandwidth theft and the [H]ardForum can get in trouble for it.
That block will not work properly on the SLI boards, which was why AC developed the TwinPlex Pro SLI Typ 1 seen below:
The following pic is why it can sit right under the video card. The video card sits in the slot. :D
You know I never realized there was a notch on the cover until I saw that last pic...
It looks like the Alphacool block is thinner instead of having a notch cut out of it. I will probably go with that one in hopes of getting compression fittings on it.
llars said:
Hey Top Nurse, Is that Chipset block I linked to above different than the one you are using in your rig?
Because from your pic there is a ton of room around the block if you are using vertical fittings.
The pic above shows a standard AC TwinPlex on an ASUS A8N-SLI motherboard. Those boards don't have that problem with the video cards like the DFI do.
Can the new twinplex pro fit there TN.
Have you run your system yet.
wait that block will fit on the asus board...even the premium...i thought that they wouldn't work?
They will fit because Asus made there board for pci-e slot to be i think 2 pci slots apart rather then like others who jsut did 1 aparts.
Also TN where do you get 45 degree fittings.
We both have Asus boards....
