Recommendations - best 24" for text
hektorrr
Everybody want the best panels for their purposes, mine is text quality cause. Picture counts as well but its latter. What you would buy thinking about these two aspects
Research ended here:
Hazro HZ24Wi (H-IPS)
HP LP2475w (S-IPS)
Dell 2408WFP (S-PVA)
Maybe even better for text quality is 23 cinema disp.(S-IPS) or cheaper Benq 23"(S-IPS) cause 0.25 pixel pitch?
H-IPS – Released in late 2006, an evolution of the IPS panel which improves upon its predecessor, the S-IPS panel. The H-IPS panel is used in the NEC LCD2490WUXI, LCD2690WUXi and Mitsubishi RDT261W 26″ LCD, Planar PX2611W[2] and Apple's newest Aluminum 24" iMac
The pick would be for sure NEC 2490 but not avalaible in Europe (I`m wondering why that model is not here, while NEC 2790 is?)
I realize that it can be boring for some of you reading similar posts through forum especially for pros, but we amateurs need pros advice the most and we value your advice the most. Thanks for understanding :)
I have NEC 2690 and I like text on it. If you want to save some money, buy HP LP2475w, it also has H-IPS panel (but not polarizer).
Any reviews available that compare the text sharpness of 24-26" monitors? What determines how sharp or clear text appears on an LCD screen?
