Recommendation?
Nexrus
I'm building a new pc from the ground up starting with the motherboard. I'm planning on using duel cards (sli) and the latest ddr memory.... it would be nice to have duel core or duel proc support as well. no pref for cpu type. amd or intel is ok. Im not looking to spend a fortune but Im also willing to throw down a couple hundred for a good one
Any recommendations?
What's your budget?
What's included in that budget?
Will you be re-using any old parts?
If so, which ones (please describe in detail)?
What will you be doing with this system, aside from gaming?
If gaming, what games?
What size monitor do you have or plan to get?
SLI is only worth the extra cost/complexity if you need more power than the current high end single card solution. You would only need such GPU power if you were running really high resolutions, at least 1920x1080/1920x1200 (24"+ LCD monitors).
What features do you need in a motherboard (raid/firewire/etc)?
If you need SLI, check out the eVGA NF68-A1 or the NF67-T1.
If you don't need SLI, go with a P35 board instead. If you don't need anything fancy, the Abit IP35-E is very affordable. If you need legacy ports, the Gigabyte GA-P35-DS3L is also affordable. If you need RAID, the P35-DS3R is good. If you need Firewire, the Asus P5K(C) is good. If you need both RAID and Firewire, then the Abit IP35 vanilla is your best choice. If you want dual gigabit lan, onboard pwr/reset/cmos switches, an extra PCI-E 4.16x slot, and uGuru OC'ing software w/ GUI, then the Abit IP35 Pro is good, and is also the crowd favorite right now. Other high end boards included the Gigabyte P35-DS4 and Asus P5K-E. Everything more expensive is just overpriced, lol... but you can get one of them if it floats your boat.
