I've looked through Mikrotik, but they don't specify if they handle VPN - do they all support site-to-site VPN?Mikrotik.
I tried looking for a place to buy the edgerouter, but all I found was dead ends.?Might be INTERESTING to setup but the edgerouter lite is an option I can also endorse.
Thanks for the information, Danne.@ Kyuki
The RouterOS does handle site-to-site such as OpenVPN although in the past OpenVPN hasn't been a great performer in terms on throughput on "low-end" SoC-platforms. It's most likely also very hard if not impossible to upgrade on your own (I might be wrong here). It's very easy on OpenWRT which essentially runs on the same hardware. Given various tweaks OpenWRT might perform better than RouterOS running OpenVPN but I havent benchmarked or anything using the same platform.
Regarding availability of the edgerouter it seems to be pretty much on backorder in .us/.eu everywhere.
//Danne
Thanks! You're sure it supports site-to-site vpn?There is a source that lists it as backordered, but ships without 24 hours of the order being received. I'll have to go digging into the ubiquiti forum to find it.
Found it: http://www.microcom.us/erlite3.html
