Recommendation for Headset and Speakers
skhuu
I'm looking to buy a wireless headset with microphone that goes over the head for around $100 or less that I can easily buy from Amazon, Newegg, Bestbuy, etc.
Also, I need to replace my desktop computer speakers since they're probably over 10 years old. I've been thinking to get either a JBL 2.1 or Logitech 2.1 speaker system. I'm not too crazy about my speakers, so I don't want to spend more than $150-$200.
Looking forward to your suggestions.
Facepalm....I just got off work so I will keep this short.
You do not want a wireless headset around $100. Unless you just want it to work. If you are deadset on that, I have not tried any so no help there.
The going headset is a Audiotechnica AD700 and a clip on Siberia mic.
Speakers, I would go with the WAF-1 and Gizmo. A bit over $200 after shipping but they will STUN you.
I believe you should look into the Klipsch ProMedia 2.1 for speakers in that price.
Another vote for the WAF-1 and the Gizmo. Nice smaller sized bookshelf speakers for PC use.
I almost bought that and paint the speakers black. If it wasn't for my interest in trying out a DIY kit, I may have purchased the WAF-1.
