I've been using the stock HD580 cables for some time now but the left ear just went out after about a year. I believe it's the cable itself since it works sporadically if you fiddle with it, and disconnecting everything and swapping the left and right cables led to the left speaker working fine with the right cable, but not vice versa (i.e. it's not the springs or the connection of the cable prongs to them inside the headphone). At any rate, what are some good, reasonably priced replacement cables for these guys? I run them amped but my source is just an Audigy 2 ZS so anything top line is probably just a waste.
Also, I was pretty surprised to see when I disassembled my cans that only those tiny little red wires are keeping the sound coming to my ears; they seem so fragile!
