what year is this?
2004, I think
At least he didn't ask for an ISA card!
I think they made a bunch of AGP 4650's. I know there were AGP 3850's and 3870's available too.
Edit: Searched newegg and sorted by AGP 4x/8x, then by 2 DVI-D and there is a dual DVI Sapphire HD4650 available.
http://www.newegg.com/Product/Produ...4102851&cm_re=4650_agp-_-14-102-851-_-Product
Yeah, you can connect DVI-D cables to DVI-I sockets. There's a limitation on the resolution for DVI-I, which if I remember correctly is that it won't support anything over 1920 x 1200. Anything at that level or below you should be okay.
Hi Everyone,
I have found the following card which should be sufficient for my immediate needs.
http://www.bestbuy.com/site/PNY+Tec...bolsp-app02-47?id=1218255999549&skuId=1407264
As informed by PNY, it has a DVI-I Single Link socket but it has the holes for a Dual Link cable just in case that is the only cable you have.
So, if a monitor, with a resolution of 1920 x 1200, has a Dual Link DVI-D socket, will a Male DVI-I to Male DVI-I Single Link cable be sufficient?
Do Dual Link cables generally cost more than Single Link cables?
Thank you,
